For a while my pc has looped on a cycle of booting up then turning off, eventually booting up normally this is after simply pressing the power button and leaving it alone, I have left it alone for the simple reason it eventually boots ands works fine however t is now doing it for even longer cycles. I have also just this morning booted up hearthstone, the Witcher 3 which have always worked fine as they are however now both and anything I play stutter and lag incredibly bad. I have disconnected everything, cleaned booted without ram in, graphics card out all does the same loop boots on all fans start 2 seconds boots off. The only thing I have not touched is the cpu could it be because it’s booting checking the cpu and it is over temperature (I’m no expert). I have also taken out left 30 seconds and put back in the cmos battery.
My specs are:
I7 processsor
Msi gtx 970
Corsair cx600
8gb 2 separate Corsair vengeance ram at 4gb
Gigabyte ga z97x-sli
Zalman 11 case
My specs are:
I7 processsor
Msi gtx 970
Corsair cx600
Zalman 11 case
