[SOLVED] PC BSOD need help please
Jan 7, 2021
14
Hey everyone, So my PC started BSOD a couple mouths ago only when I am playing games (well I think its only happening on one game but I rarely play other game and I don't remember getting a BSOD for other game and sometime any game just crash with no BSOD )
I have try a lots of things like windows memory test memtest86 ( no errors found ) driver verifier I have reinstall widows and nothing work now I am lost and do not know why I am still having BSOD If someone can help I will really appreciate that you.
System Information (local)
Windows version: Windows 10, 10.0, version 2009, build: 19042
Windows dir: C:\Windows
Hardware: ASUSTeK COMPUTER INC., TUF GAMING X570-PLUS
CPU: AuthenticAMD AMD Ryzen 5 3600X 6-Core Processor 8664, level: 23
12 logical processors, active mask: 4095
RAM: 17089822720 bytes (15.9GB)
GPU: GTX 950
PSU: antec neoeco 610w 80bronze +
SSD: kingston A400 480gb
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Thu 2021-01-07 5:29:44 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010721-4859-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F5780)
Bugcheck code: 0x139 (0x3, 0xFFFFA60BA5CC37E0, 0xFFFFA60BA5CC3738, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The kernel has detected the corruption of a critical data structure.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!setjmpex+0x8299)
On Thu 2021-01-07 4:50:23 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010721-7187-01.dmp
Bugcheck code: 0x139 (0x0, 0x0, 0x0, 0xFFF)
On Mon 2021-01-04 10:51:40 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010421-5203-01.dmp
Bugcheck code: 0x1A (0x61941, 0x7FFBF8ED77A6, 0x1D, 0xFFFFFC0BE31F0B00)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
On Fri 2021-01-01 11:38:59 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010121-5515-01.dmp
Bugcheck code: 0xA (0x200, 0x2, 0x0, 0xFFFFF8055F5191DE)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
On Sat 2020-12-26 5:32:27 PM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\122620-5593-01.dmp
Bugcheck code: 0xA (0xC9, 0x2, 0x0, 0xFFFFF8030746585C)
Conclusion
6 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
i don't suggest blind replacement as it can get expensive long before its fixed. I have seen people replace almost everything and its that 1 part they didn't replace that was cause. So no, that isn't funny.
if it makes you feel better, lots of people have been getting same BSOD recently and I am getting tired of seeing them.
we haven't really looked at hardware, all the fixes mostly suggested so far are software fixes.
Memory
if you go to the G Skill memory finder, search for your motherboard and narrow down search to sets of 2 x 8gb and 3200 speed, they didn't test any ram that has your rams scores
the ram sticks are either 16-16-16-35, 16-16-16-39, or 18-18-18-43
Gskill search - link
So if you going to...
Memory
So if you going to blindly replace parts, ram would be a good place to start.
