PC Build Components for loading webpages fastest?
michaelbaker120
19
Part of my business depends on being able to load webpages faster than my competitors. Even if it is only .1ms faster, are there certain components I should purchase in order to load/display webpages faster?
If you already have a decent graphics card and ram, you should just upgrade to SSD storage and get a faster CPU, and keeping your storage clean also helps out a lot with fast refreshing and startup. So try to avoid any unnecessary programs.
The three most important things in order are good internet, an SSD and ram. Your competitors probably have similar internet to you but poor computers. I don't know how much your willing to spend. If you get the best of the top three things above along with a top cpu and graphics card you have the fastest loading times.
I am looking to build a custom PC from here:
https://www.maingear.com/boutique/pc/configurePrd.asp?idproduct=2325
It has an Asus Z10PE-D8 WS motherboard. What ethernet card does it have on-board and how does it compare to the Killer E2200?
Would I be able to purchase a separate high-end ethernet card instead of using the on board ethernet card if I wanted to? I did review killernetworking.com and like the idea of prioritizing specific website traffic.
I'm not sure what the LGA2011-3 is. If you are referring to the dual CPUs I need those for virtual machines.
Can you recommend a gigabit network card that I can upgrade to that will be at least as fast or faster than the Killer E2200?
The motherboard for the PC build on this site is the Asus® Z10PE-D8 WS:
I'm not sure what the LGA2011-3 that you mentioned is.
I would like to know what ethernet card the Asus Z10PE-D8 WS uses and how comparable it is to the Killer E2200. If it is not as fast as the Killer E2200 then I would like to know if I can purchase a stand alone upgraded ethernet card that can perform as fast as the Killer E2200.
