[SOLVED] PC build components
himedavito
64
Hello i want to know your opinion on my pc build is it good / bad / or did i do it pretty randomly stupid .
Part list
Case:Masterbox 5 Lite
Motherboard: MSI B450 Pro carbon ac
CPU: Amd ryzen 5 3600x
Ram:Corsair vengeance 16gb Kit of 2 (8+8) 3200 mhz
GPU: Asus Rog strix 5700xt 8gb OC gaming
PSU:Corsair RM650 W
SSD:M2 Samsung evo 970 plus 1 tb
CPU Cooler:Cooler master Hyper H412R
I didnt know exactly wich topic to put this post in , so i tought components would be most logic decision.
I think it looks good.
I wouldn't buy the Hyper 412R. It's a dated design and a 92mm fan. Give it a go with the included Wraith cooler first.
I bought it because i read that bonus cooler is pretty bad that might cause overheating , after some time i will replace with liquad cooling . U think wraith would be better? As a performance not looking on design and size
The Intel Stock coolers were/are pretty worthless. The AMD cooler on their X series CPUs is actually decent. You can still do better with an aftermarket cooler of course, but since the AMD cooler has a 92mm fan, you generally want to swing for a minimum of a 120mm tower-style cooler.
Reactions: himedavito
