Pc Build for Gaming and Rendering
Anarchitect
6
Introduction: Hey Forum. I need your help to build a desktop for gaming and rendering (autocad, revit, etc). Also, I would like this build to run The Witcher 3 on maxed out (or very high) settings when it comes out.
Approximate Purchase Date: December 2014 - February 2015
Budget Range: 1000 € - 1500 €
System Usage from Most to Least Important: Witcher 3 maxed settings (or very high settings), Rendering images for my project in Landscape Architecture
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: No
Parts Preferences: Geforce Gtx 970 (because I heard that it might run directx 12 when windows 10 comes out)
Overclocking: Maybe
SLI: No
Monitor:No
Additional Comments: I would like the build to have somewhere between 16 and 32 gb RAM and an i7 cpu... possibly Intel Core i7-4790K.
This would suffice your gaming as well as rendering needs:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (€303.30 @ Amazon Italia)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (€46.44 @ Amazon Italia)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard (€102.04 @ Amazon Italia)
Memory: G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2400 Memory (€170.87 @ Amazon Italia)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive (€103.45 @ Amazon Italia)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (€52.75 @ Amazon Italia)...
Salut!
Around 4000-6000 Ron eh?
I ordered something for about €1500 (Mindfactory.de prices, will be built myself) and they should come on week end.
But...I dunno how are the prices in Rumania tho'.
i7 4790k (€299)
ASUS Maximus Z97 mark 2 (€132)
Galax GTX 970 EX OC (€329)
BeQuite! Shadow Rock Slim (€33)
Crucial Ballistix Tactical 16GB DDR3 1600 CL8 (€159)
Samsung 840 500GB EVO (€195)
Seagate 3TB 7200.14 (€87)
Fractal Design Define R4 (€85)
XFX 750W XXX (€88)
LG BlueRay burner (€63)
(I rounded the cents down for quick typing)
Alternatives, if you do not plan to OC. E3-1231V3 is nice.
If you do not plan to OC and not to SLI, ASUS H97-pro gamer is also nice.
Video Card: Zotac GeForce GTX 970 4GB AMP! Omega Edition Video Card (€389.99 @ Amazon Italia)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (€109.35 @ Amazon Italia)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (€54.81 @ Amazon Italia)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive (€19.45 @ Amazon Italia)
Wireless Network Adapter: TP-Link TL-WDN3200 802.11a/b/g/n USB 2.0 Wi-Fi Adapter (€14.84 @ Amazon Italia)
Total: €1367.29
Generated by PCPartPicker 2014-10-09 13:41 CEST+0200
I will second Meteors build with the exception of the motherboard and GPU. For the extra money, I would personally grab Asus versions of the Z97 mobo and 970. I heard ASRock quality is abysmal and I never dealt with Zotac but I would rather a manufacturer with a high consumer rating.
Last week I was able to buy MSI GTX970 4G.
This week, I am looking for one more of those but it is hard to find.
GTX970s from eVGA, MSI, ASUS, Gigabyte, etc. are/were really rare this week.
I grabbed Galax because it was the only one available as I ordered it.
I am unfamiliar with Galax a.k.a. TFA2 a.k.a Galaxy..let see how the VGA will really look like.
About the Haswell-E, The problem with this platform is the price of the DDR4 RAM.
At the moment, I see that this platform does not really worth the price unless you either want it bad or need it desperately for a stronger i7 (above €500 class) and/or for much RAM >32GB.
Broadwell will come most-likely next year and the compatibility to Z97 is not guaranteed but the potential is there.
About how good Broadwell will be, I can not tell anything since I do not know anything about it.
Z97 and H97 will support Broadwell, its garuanteed by Intel. And Broadwell will not be anything more than 5-10% better, not worth waiting IMO. For Haswell-E, your purpose, unless you do it on an absolute extreme level, doesn't require a 6 core on the least. You can go with it, there's no issue in that, but will that be much better than 4790k and jusitify the price difference? No IMO.
