[SOLVED] PC Build for running multiple instances of Bluestack ?
Feb 23, 2022
Im planning to build pc for 4 bluestack instances:
CPU i7-3770
GPU GT 730 2gb
RAM 16GB DDR3
128gb ssd
Amptron H61 motherboard
Are those specs enough for 4 instance of bluestack with synchronisation on?
Any recommendations with the specs?
my budget is quite low 300$~
Android emulators will run on a potato, since the games are coded to run on a smart phone, which isn't much more than a potato compared to the computational power a pc can bring to bear.
Min requirements is a cpu with passmark single thread of 1000, gpu of 750. The 3770 is 2068
CPU i7-3770
GPU GT 730 2gb
RAM 16GB DDR3
128gb ssd
I can't find a recommended configuration. Even the multi-instance manager on the Bluestacks webpage does not provide any help. It may depend on what game your are using in each instance.
