PC build Help
wahabthesmasher
16
http://pcpartpicker.com/user/wahabthesmasher/saved/3O3V
So i am going to get this new computer because my computer is old and cant play games. The link is above i put the parts. But the question is do i need a case fan, an audio drive. And how much ports dose is have (USB) i have no idea even though i built it. i need 5 usb ports 4 back and 1 front please reply with my mistakes and you know stuff
EDIT: go down for new computer setup and tell me the mistakes please?
kamilstoch
149
7
Mistakes:
1. 16GB for that system is complete overkill. 8GB is more than enough.
2. You won't play games with that GPU and CPU (unless you play flash games on Chrome)
3. Don't need a liquid cooler at all (CM 212 is enough)
4. Actually, you don't need a cooler at all, unless you're overclocking
5. Save $50 and go for Windows 7 Home Premium unless you really want Windows 8.
6. Get one set of 1TB storage for about $60 (WESTERN DIGITAL or SEAGATE are really good)
wahabthesmasher
16
Some AMD 970 chipset motherboards may need a BIOS update prior to using Vishera CPUs
do i worry about that.... well right now i am editing my parts from kamil reply
verma1891
888
138
ddont worry, its not an issue.
wahabthesmasher
16
look at this: http://pcpartpicker.com/user/wahabthesmasher/saved/3O7Y
what do you think
verma1891
888
138
Not good.
1. Older cpu
2. Single channel RAM
3. Stone age HD 5450 (NO games will be playable on 1080p)
4. 8.1 is available in 99$.
Why dont you just go with the build I suggested? Its best you can get at this price and you can play games on it too.
wahabthesmasher
16
it was just because i was working on it then i saw yours... im getting yours now btw i relized on forums people with assains creed guy are usually correct i mean really go to other forums and see (PC related forums that is)
verma1891
888
138
Hehe.. Nothing is true, everything is permitted :D Hail edward kenway :D
Happy to help. And thats dp is just because I am a big fan of the assassins creed game series :)
