PC Build Help
FlyeBye
I've reworked my budget to find something that I think will deliver splendid performance at 1080p ULTRA settings. Please tell me if the following specs are COMPATIBLE (MAIN THING) and if they will deliver good performance at 1080p. Parts in links are ones i need to buy, and parts in words are ones that i already own.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369&cm_re=i7_4790k-_-19-117-369-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011&cm_re=Phanteks_PH-TC14PE-_-35-709-011-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770&cm_re=z97-_-13-130-770-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127832&cm_re=gtx_970-_-14-127-832-_-Product
Corsair TX 750W
8GB Ripjaws X G-skill RAM
1TB HDD
Antec P182 Case
So are all these compatible? And will the cpu cooler fit in my case? And will the PSU be enough?
Try this: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=Cooler_Master_Hyper_212_Evo-_-35-103-099-_-Product. It is cheaper than the one you have, and has a higher possible airflow at max RPM. It should have no problems with clearance... A good option, I think.
