PC Build Help
Marthin13
Commendable
Feb 21, 2016
Hi, this is my first attempt to build a pc on my own, so I would like to know if everything is compatible and working nicely together, does psu have enough power, will gpu fit in the case, and if this build is capable of handling some gaming, 3d modeling, and heavy photoshop usage.
Also, if you have any suggestions on better part optioms in similar price range feel free to suggest.
Here is the build (hhd is not included, have an old one):
http://pcpartpicker.com/p/JGbr23
Well for your first time I'm highly impressed ...
I would only change the cooler to a Cryorig H5 Universal for better cooling and zero ram interference.
Hi - Good build & yes the PSU is plenty for that rig with a r9 390
Maybe add one front intake fan
