Pc build info
Alexandre_19
hey guy im looking to build a pc for gaming i have 2 build that i make wanna know wich build is best ore you can tell me a other build i can make for 1800$ Canadien for only the computer. I have the SSD and HHD
build 1
Corsair Crystal Series 460X RGB – Tempered Glass Compact ATX Mid-Tower Case CC-9011101-WW
INTEL® CORE™ I7-7700K Processor 8M Cache 4 Cores 4.2GHZ Up to 4.5GHZ FC-LGA14C Retail Box Kaby Lake
ASUS Prime Z270-A LGA1151 Kaby Lake DDR4 DP HDMI DVI M.2 USB 3.1 Z270 Aura Sync ATX Motherboard
MSI GeForce GTX 1070 Twin Frozr VI 1607/1797MHZ 8GB GDDR5 G-SYNC Vr Ready Video Card
Corsair Cooling Hydro Series H100I V2 CPU Cooler System LGA1151/1150/1155/1156/AM2/AM3/FM1/FM2
Corsair CX Series CX750M 750W ATX 12V 80 Plus Bronze Modular Power Supply
Kingston HyperX Fury Black 16G 2X8GB 2133MHZ DDR4 NON-ECC CL14DIMM Dual Channel Memory
build 2 almost the same but with a SLI
INTEL® CORE™ I5-7600K Processor 6M Cache 4 Cores 3.8GHZ Up to 4.2GHZ FC-LGA14C Retail Box Kaby Lake
Get this, you're spending too much on visuals.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($453.98 @ DirectCanada)
CPU Cooler: Phanteks PH-TC12DX 68.5 CFM CPU Cooler ($55.99 @ Newegg Canada)
Motherboard: Asus PRIME Z270-A ATX LGA1151 Motherboard ($207.74 @ shopRBC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory ($129.99 @ Newegg Canada)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card ($779.99 @ NCIX)
Case: NZXT S340 (Black) ATX Mid Tower Case ($74.99 @ Newegg Canada)
Power Supply: EVGA SuperNOVA G2 550W 80+...
Depends on what you are after. Sli is great in some games, mediocre in some and almost non existent in some, so if you happen to prefer the games sli is good for, build #2 will work fine. And then there's games like BF1 and Starwars Battlefront that can really use the extra threads of the i7, and can suffer with an i5. Even GTA:V when modded can bog down an i5 easily. So if those are the games you prefer, then build #1 would be better. What I don't see is the monitor. A single 1070 is plenty for 1080p/144Hz or 1440p/60Hz and can do well with a 1440p/144Hz, but if the monitor is just 1080p/60Hz, there's no point in sli at all.
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Amazon Canada)
Total: $1802.67
Generated by PCPartPicker 2017-02-14 22:50 EST-0500
