Hello, I am going to build a pc using new pieces from Newegg and a few from my current setup. I would like to know if there are any things I need to change, or just advice on parts to use for my pc.
My parts include:
CPU-(i5-9600k ($365) or i7 8700($416) I'm not sure which one I want to get but input would be gladly accepted 😀
GPU- 1660 6gb
PSU- Cooler Master 750w
Memory- Corsair Vengeance DDR4 2400 16gb (2x8gb)
Motherboard- ASRock z390 pro4 (Comes in a bundle with the CPU and links for the bundle is below 😀 )
i5 Bundle- https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3878867&Description=i5 9600k combo
i7 Bundle- https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3885905&Description=i7 8700 combo
If there is anything you would like to say or mention I would gladly like to hear it thanks again
Edit: As I don't yet have the GPU, CPU, Ram, or Motherboard would a 750w power supply and an i7-2600 work with a 1660 6gb? Thanks.
My parts include:
GPU- 1660 6gb
