GPU 1060 3g
CPU I7 3770k
Motherboard ASRock Z77 Extreme9 LGA 1155
Hi I got a motherboard and CPU to replace my older build, when I booted up the pc it turned on for about 5 seconds then it turned off. I looked it up and someone
online said it could've been bent pins so I removed the CPU and I aligned the pins (the pins are on the motherboard socket not on the CPU) after that
the pc stayed on but it shows no display and it didn't show display before either, all the fans and LED's turn on.
Any tips would be appreciated
Thank you
CPU I7 3770k
Thank you
