Pc build thoughts
Asura_San
I am building a PC and wanted to know everyone thoughts, This build will be used for Gaming, Livestreaming mainly. my max budget is $900 USD
Build: https://pcpartpicker.com/user/AnimeChaos/saved/#view=qPnCmG
AMD FX-8350 4.0GHz 8-Core Processor $163
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler $28
Asus M5A97 R2.0 ATX AM3+ Motherboard $89
G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory $59
Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive $49
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive $47
MSI Radeon R9 280 3GB TWIN FROZR Video Card $183
Corsair Carbide Series 300R Windowed ATX Mid Tower Case $79
Corsair Builder 600W 80+ Bronze Certified ATX Power Supply $39
The 8350 is just fine. It's a fine CPU and outclassed the i5 for video editing: more cores.
Jan's two cents has a video on YouTube on this.
I have a 4690k myself but it depends on your budget too.
The only thing I would change in your build is to take a western Digital hdd instead of Seagate.
There's an article on. Arstechnica on hdd showing Seagate fail a lot.
Also you could check if a gtx960 or 970 would fit your budget instead of that 280.
I do not know much about live streaming but i would imagine it would be fine. But for gaming it would be great.
