Pc can do this if the cmos battery dead ? Urgent please help.
Jun 1, 2018
18
Hi yesterday i restarted my computer and won't restart (monitor write no signal) and after i use restart button not restarted. (I can turned off the power button 5s.)That happened 4x time. I try clear CMOS bios setting with a jumper on mb but not worked. I removed a CMOS battery for 30 second and used the jumper to clear CMOS setting fixed the problem. Sometime happen weird things not boot a pendrive and freeze but i clear CMOS fix that.
Can fix that if i change a new CMOS battery ? Motherboard: Asrock fm2a55m-vg3 and bought 2013. Thanks for help sorry for poor english.
Thanks i tried restart my computer and i think frozen every tries. After removed a battery fixed.
And sometimes have problems but if clear cmos fix that.
I buy a new battery.
Can i put 5V cr2032 battery to my motherboard i have now a 3V version?
Thanks for help i use 3v version. You have no idea if CMOS battery low can do computer not restart or not boot from usb goes freeze and i clear CMOS fixed this problems for a little time. That means 1 week or 4 month.
