PC Case Build - Negative Air Pressure
Curious User
20
Built a pc with 2 chassis fans, 1 for intake (front) and 1 for exhaust (back)..
I've been thinking, is it ok to remove intake and move it to the top for another exhaust? So I have 2 exhaust and zero intake.. the intake corner has dust filter installed, so dust is not a problem.
My PC Case is Thermaltake Versa H15
http://www.thermaltake.com/products-model.aspx?id=C_00002582
Back exhaust and top exhaust.. no intake fan, front is an open grill with dust filter.. check the site for visual.. is it a go go? or a no go?
If you have more exhaust than intake, air won't care about where it comes into your case. Some may come through the dust filter. Most will come through various other gaps and vents that aren't filtered.
