Question PC Case Cable/Motherboard Help
BeadyRoller
69
Hi guys, I'm building a PC for my cousin who has an RGB case (Liam Li Lancool-II https://lian-li.com/product/lancool-ii/) and I've never dealt with RGB before so I'm unsure on where some of the cables are meant to be plugged in.
Motherboard used is a Gigabyte B550M DS3H mATx.
I've looked through the manual and watched YT videos but still not confident where they need to go. Heard some stories that if you plug RGB stuff in the wrong place it can ruin the board so a bit nervous 😢
Here's the pictures of said cables:
https://ibb.co/NK8JQVC
https://ibb.co/jZfm6QY
https://ibb.co/8DcNj5F
https://ibb.co/HzFMhvL
Any help would be appreciated, cheers!
This;
goes into the PSU's end.
This;
goes to the motherboard where you should see a header labelled D_LED1 or D_LED2 located at the top left corner and the bottom right of this image:
1000
You can use your motherboard manual to locate the header stated above. Also, this;
is very likely to daisy chain other ARGB devices which will explain why there are pins and not holes underneath that sheath/cover.
