PC case fan
mixdix123
42
Hello, I have recently bought an pc case fan, but I am afraid of it that I haven’t any second connector for the second case fan. Tell me if I am wrong, and if there can something else been done about that.
PC Case: Coolermaster Elite 332
PSU: XFX Core edition 550W
Motherboard: MSI 760GM-E51
one thing we need to know is the model number of the fan you bought. it will have one of 3 types of connectors: 1. a 4 pin molex connector that would plug into the power supply. 2. a small 3 pin connector that looks like the CPU fan connector and will plug into the motherboards extra fan header. 3. a small 4 pin connector that will look exactly like the CPU fan plug. this will also plug into a motherboard fan header.
options 2 and 3 and be adapted with a wire adapter to plug into the PSU's molex connector. So to answer your question yes you will be able to connect it, just how to I can not help you with without knowing the plug style. This is why we need the make and model number of the fan.
model number please. I will need to look it up to find out.
after reviewing your motherboard there is a 3 pin system fan connection ( fan header ) just under your Sata ports that a option 2 and 3 can plug into. option 1 will connect directly from the PSU.
What kind of model number of the fan do you mean. In the pack there was an number 4044951005604 and a second 050.908.103. If you mean the number of the connector thats TKG 2510. Others number were not in the pack.
And I have an case can connected to the motherboard but i bought an second one to have two of them.
And sorry for my bad english.
