K kyleice441 Prominent Sep 7, 2017 15 0 510 Sep 9, 2017 #1 My pc case has a side panel on both sides for cable management but I have no cable management holes so my assumption is that was intended for modding, what tool should I use to do this mod?
Solution CountMike Sep 10, 2017 Wrong assumption, many cases have both removable side panels. Tool you need is something like this https://www.amazon.com/gp/product/B00GGT8HWM/ref=s9_acsd_zgift_hd_bw_bHLLxT_c_x_w?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-5&pf_rd_r=W7QAGDE2SPM98HX2VG95&pf_rd_t=101&pf_rd_p=a205008f-a286-5c0d-8398-4a56b6137dbb&pf_rd_i=256287011 to make holes of appropriate size and in right places to push cables thru. One other thing to watch out for, see if there's enough space between back cover and back plate for MB as cables may be too thick to fit in there.
CountMike Titan Oct 31, 2015 35,693 3,859 147,990 Sep 10, 2017 Solution #2 Wrong assumption, many cases have both removable side panels. Tool you need is something like this https://www.amazon.com/gp/product/B00GGT8HWM/ref=s9_acsd_zgift_hd_bw_bHLLxT_c_x_w?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-5&pf_rd_r=W7QAGDE2SPM98HX2VG95&pf_rd_t=101&pf_rd_p=a205008f-a286-5c0d-8398-4a56b6137dbb&pf_rd_i=256287011 to make holes of appropriate size and in right places to push cables thru. One other thing to watch out for, see if there's enough space between back cover and back plate for MB as cables may be too thick to fit in there. Upvote 0 Downvote Solution
