[SOLVED] PC Case Questions
bikemanI7
242
17
10,595
Hello all
Got a Custom PC built a while back locally here by a shop, anyways discovered once got it home, no extra Motherboard standoffs, screws or anything, what should i do someday if i wanted to upgrade from Micro ATX to Full ATX motherboard in the system, or if i needed screws for something.
Case is Thermaltake V200 RGB
Current Hardware inside
Gigabyte B460M-DS3H
Intel 10700
Geforce 1660 Super
16gb of Crucial Ballstix ram CL16
1 Samsung 970 Plus 500GB M.2
1 Samsung 860 Evo 1TB Sata SSD
1 WD Black 4TB Storage drive
Thermaltake 3 Front fans 120mm hooked up to Thermaltake V200RGB Fan Controller/RGB Controller
1 Thermaltake 120MM Stock in the rear
EVGA G3 650 Power supply
Hello all
Gigabyte B460M-DS3H
Intel 10700
Geforce 1660 Super
Really you can get away with one in the...
Hello all
Gigabyte B460M-DS3H
Intel 10700
Geforce 1660 Super
Really you can get away with one in the middle and outside screws really. mAtx usually uses about 6 and a FATX can use 9 but you could get away with no slotting 3 in and it will be fine.
Oh ok thank you for this reply, makes me feel better in case in the future if i wanted a Full ATX board, though to make things easier in future, i may just choose another Micro ATX, as imagine it would be same standoffs if i got another Micro Atx in future if and when i upgrade board, and processor again in a few years
