Question Pc completely damaged by a power surge?
RubberDucky 123
21
Hi there, my pc went completely to black during the middle of gaming and I was unable to turn it back on. Fast forward to me taking up the pc repair shop hes come back after 2 days and said my cpu, motherboard have been completely fried and my 3080 graphics card is in "intermission". The cause a power surge apparently. This is really confusing to me because I had my pc plugged into a power surge protector. So how has basically my entire pc been damaged completely to the point where its unusable even when i have bought a surge protector for this exact reason? Am I being scammed? Should I take my pc to another shop for a second opinion?
I'll be interested to hear from this forum what you guys think. If you would like me to expand further please ask
Many thanks,
Jordan
PSU can fail - yes,
GPU can fail also.
Motherboard failure - less likely.
CPU failure is highly unlikely (unless it was heavily overclocked).
If AIO radiator failed and leaked all over internals of your pc, then yes - that would be possible.
PSU can fail - yes,
GPU can fail also.
Is it really possible that a power surge could damage my pc parts even if i am using a good surge protector?
Thanks
Some are good some not so good depends on what you bought. Also nothing is actually fail proof.
Should you get a 2nd opinion on the PC 100% yes.
I had the Belkin 4 Socket Outlet 2 Meter Surge Strips. They were recommended to me by one of my friends. I dont even know if I had a power surge, theres no evidence aside from a person in a pc repair shop saying I did.
Thanks
You definitely should get a second opinion before paying that guy a penny. While you're at it, try to get an explanation of what GPU "intermission" means :)
The only peice of tech that will protect you from a massive surge is an ups, that'll also protect you from brown outs as well.
Those surge protectors for 20 quid or so are pants tbh
I assume that is a misheard or mispronounced "Intermittent"
Yeah you are correct. I am pretty sure I had heard him say "intermission" in the first phone call, but when I called him back to clarify what he meant he said "intermittent". No idea if I missheard it or he mispronounced it.
Anyway I have taken my PC to get a second opinion so i'll update here once I hear back
good surge protector has warranty which should cover your connected equipment
I checked the website I bought the power surge protector from and they give a £20,000 connected equipment warranty. That is if there was a power surge that fried almost every part of my computer. I am starting to doubt the first diagnosis to be honest, there is no evidence there was even a power surge in the first place but I'll wait and see what the other pc repair shop says before I make a decision on what to do next
525 joule surge protection...thats good for lamps, mobile chargers and such, definitely not recomended for gaming PC, coudl work in home-office enviroment..low power PC, laptop, printer, router
Thats the thing I am pretty certain the power surge didnt happen anyway. I will definitely be investing in a higher joule surge protector once the dust has settled and I find out what actually happened
Reactions: Richj444
