Just built a new PC with all new components and it the power is flashing on and off. I can't start PC it could be a 24pin cable error. I can't check cpu because it takes hours to rebuild case fan.
Specs:
AsRocks h61. MATX motherboard LGA 1155
i5 2400
F3 Case
Hyper 212X
PC does not boot at all and no power button Leds show. Thanks in advance. Help...
UPDATE
It boots but does not display. All fans and LEDs work and the power button boots it up. 24 cable wasn't inserted properly. But, the display does not work.
Specs:
i5 2400
F3 Case
Hyper 212X
UPDATE
