PC do not post
Tania_04
26
This is my first build.
PCU Corsair AX760 Pro
Motherboard Asus Rog Strix Z370 H
CPU i7 8700 Hexa Core 3.2Ghz
Corsair Hydro H100x Liquid Cooler
Corsair Vengeance RGB 16gb 8x2 3200 mhz
i connected all components but pc does not post. The Led Ram light lits up as orange on motherboard. I notice that the RGB lights on Ram does not lit up at all.
i tested the RAM on a other pc and on that pc it lits up and the pc post. So the problem is not with the RAM.
i think i may have a dead motherboard RAM slot... i am not sure. Or worse... cpu
The RGB on the motherboard lits up. Thats about it.
i did try only one RAM in the slot and tried it on every ram slot.
does anyone have advice?
just want to thank both of the answers i got. I found the mistake and of course it was my own. The RAM at the end was not seated fully. i Think allot of new builds will have this with the Asus MB. The RAM slots only have one movable slot pin at one side. And you have to look very sharp to see if the RAM are level. So make sure the unmovable end of the slot indeed go in deep. So that the RAM is totaly level. My PC posted and now i am happy. Thanks again for all the in putts.
