[SOLVED] PC fan ridiculously loud
tacticalkali
95
So I have some Corsair AF120 s in my PC, they are just under4 years old. Recently they've become very, very loud, almost as if it is grinding something. It seems to be FAN_1,. I've used speedfan and found that it is going as fast as 1979rpm . After about a minute or so they stop. Is this a problem with the motherboard or the fans? I'm replacing the fans so it doesn't matter if its them. Thanks (the problem is intermittent)
What you describe sounds a lot like the early stages of fan bearing failure. Over time and use as the bearings wear the gap between shaft and bearing bore gets bigger. That gap also depends on the temperature of the bearing system because the metals expand differently. When the fan is cold the gap is larger, and in a worn bearing it is large enough that the shaft "rattles around" in the bearing bore. But as it warms up and the gap narrows, that stops and the fan becomes silent. In the early stages that may take up to a minute, but as more wear happens it takes much longer, and eventually it never stops being noisy. Last stage is total failure that seizes the fan, but that normally takes a couple years to develop that far. Since you plan...
Maybe they always spun this way but you are only noticing it now because one (or more) of the fans bearings is grinding?
I would replace the fans first and then see how it sounds.
I've found a fair bit of dust in the rear fan that is the FAN_1, I've cleaned it out and it seems to be okay but not convinced. I'm upgrading the case and fans soon anyway so we will see
According to your manual: https://download.gigabyte.com/FileList/Manual/mb_manual_ga-z97(h97)-d3h_e.pdf
Yes, your board does support 4 pin CPU and System fans. PWM fans are 4 pins, analog fans are 3 pin.
You have 3 system fan headers.
If your case support 140mm fans, I would upgrade if you can. Amazon sells 2 packs, which aren't too bad in price: https://www.amazon.com/Corsair-Prem...keywords=corsair+ml+fan&qid=1571404788&sr=8-3
Or course they have 120mm fans as well: https://www.amazon.com/Corsair-Prem...keywords=corsair+ml+fan&qid=1571404788&sr=8-5
I've read though that only the CPU pins are PWM enabled
I'm not sure what's going on with their documentation, but 4 pin fan headers are for PWM, I don't see a reason to have a 4 pin header with just analog control because a 4 pin fan fits on a 3 pin header just fine. It just hangs off the side. Most likely those headers are designed for dual use 3 and 4 pin, so the documentation is a little funky.
But if you look at page 44 and 45, it does say the system fans use some kind of PWM scheme:
"Fan Speed Percentage Allows you to control the fan speed. This item is configurable only when 1st System Fan Speed Control is set to Manual. Options are: 0.75 PWM value /oC ~ 2.50 PWM value /oC. "
The cpu_fan header is almost always dedicated pwm, no analog control, a constant 12v. The other sys_fan headers are either, can be pwm or analog voltage. The 2 use different buss addresses, so are independent of each other, but sys_fan headers can share the same buss, so what you set for 1 fan is what's set for all those system fans. Some sys_fan headers might be on a seperate again buss, older boards especially had no issues running 3pin on one header and 4 pin on another.
The easiest way to see this is in SpeedFan, you'll see certain groupings, fan1-fan2, and another Fan1-fan2 etc and the isa buss is the same for each group but different from the other groups.
What you describe sounds a lot like the early stages of fan bearing failure. Over time and use as the bearings wear the gap between shaft and bearing bore gets bigger. That gap also depends on the temperature of the bearing system because the metals expand differently. When the fan is cold the gap is larger, and in a worn bearing it is large enough that the shaft "rattles around" in the bearing bore. But as it warms up and the gap narrows, that stops and the fan becomes silent. In the early stages that may take up to a minute, but as more wear happens it takes much longer, and eventually it never stops being noisy. Last stage is total failure that seizes the fan, but that normally takes a couple years to develop that far. Since you plan to change soon, you already have the proper solution in mind. Just wait until you change the fans, anyway.
Regarding your new fan choice you CAN use PWM fans in your system. That is not becasue the SYS_FAN headers are set up right - the manual indicates it is not, and the three SYS_FAN headers all appear to use only the older Voltage Control Mode (aka DC Mode). That Mode is the only way to control the speed of 3-pin fans, so if you are alreay using 3-pin ones and their speed IS under automatic control, then that is what your SYS_FAN headers are doing. So you COULD use 3-pin new fans if you choose to, and (among others) Noctua includes in their line-up almost identical models of the same fan in both 3-pin and 4-pin types. But one of the design items of the new 4-pin PWM fan type is a backwards compatibility feature so that these fans CAN have their speed controlled by any header using the older Voltage Control Mode (aka DC Mode). It is not quite ideal for that fan type, and such fans typically cost slightly more, but it DOES work.
The number of pins on a mobo fan header does NOT tell you what Mode it uses. Virtually all mobos today are using 4-pin headers because you CAN plug either fan type into such a header, but the the electrical signals from the header could be any of four types:
  1. Header uses only the older Voltage Control Mode, and CAN control the speed of both fan types because of the backwards compatibility feature of PWM fans (this appears to be what your mobo does);
  2. Header uses only the new PWM Mode which cannot control the speed of a 3-pin fan - it will always run full speed - but can control speed of a 4-pin one;
  3. In BIOS setup you have an option to configure the header to use either one Mode or the other so that you can set it to work with whichever fan type you connect; and,
  4. Fan header can do either MODE type and claims that automatically it will detect the fan type connected and switch its Mode to match.
Note that it is possible (and I'm sure this was done several years ago by a few mobos) to claim the "automatic configuration" feature (4 above) while actually only doing the "DC Mode only" (1 above) because even a 4-pin fan WILL be speed-controlled and you would not notice the difference unless you try to use them a little differently.
Also note that, because the two fan types require different Modes for ideal control, you should plan NOT to mix the two types (using a Splitter) on the same header. Keep different types on different headers and configure each header to suit the fan(s) connected to it.
Reactions: Karadjgne
