So i am planning to build a new computer in 2018 and i don't know if the parts are going to work together...By ,,together'' i mean will it work....
So the parts are:
Cpu: I5-7600k base clock 3.8ghz boost clock 4.2ghz 91watts
Gpu:GIGABYTE GV-N1070WF2OC-8GD 8gb vram , 500watts , 8 pin ,pcie 3.0 , Boost: 1771 / Base: 1582 in OC Mode , Boost: 1746 / Base: 1556 in Gaming Mode
MotherBoard: ASROCK Z270 PRO 4
Ram: TEAM GROUP DELTA RED DDR4 - 8GB 2400MHZ
Cpu Cooler: COOLER MASTER HYPER 212X, AMD/INTEL
PSU: COOLER MASTER MASTERWATT LITE, 600W 80+
HDD: SEAGATE, 2TB, 64MB, 7200 RPM, SATA 6.0GB/S
Thank you
So the parts are:
Thank you
