Build Advice PC for CAD purposes
gtsolid
155
Hi,
I'm using SolidWorks 2020 for CAD purposes and I notice it's getting older, so i'd like to buy some high-end component to replace it.
Approximate Purchase Date: March 2023
Budget Range: 2-3K (not really a fixed budget, I can be flexible)
System Usage from Most to Least Important: Heavy drawings with Solidworks.
Are you buying a monitor: No
Parts to Upgrade: Everything except Mouse, Keyboard and Monitor
Do you need to buy OS: No
Preferred Website(s) for Parts:
Amazon, eBay
Parts Preferences: No Preference
Overclocking: No
SLI or Crossfire: Why not
Your Monitor Resolution: 1080p
Additional Comments: I work in an environment in which the components are stored into a server running Windows Server 2019. 1 gbps network
I noticed AMD CPUs are more interesting than in the past. Since now I've only used Intel.
Hi,
Amazon, eBay
Overclocking: No
Have you read this page -- https://www.pugetsystems.com/solutions/cad-workstations/solidworks/hardware-recommendations/ Puget Systems is a boutique workstation builder.
