Hello All,
First here is my build: http://pcpartpicker.com/list/7JHZWZ
This was my first computer build that I built right around the time that the GTX 970 came out. Recently when I have been playing games (play time varies from 15min to 1hr) my computer randomly freezes with a black screen with the audio still playing in the background, and I am forced to turn off the computer. I also noticed that if I right click the context box is blank, same when I click the taskbar arrow at the bottom right to view additional notification icons. First I did a fresh reset to reinstall Windows 10 because it seemed to have started after a recent update, didn't fix it. Then I ran Memtest to check the RAM, did 15 passes which took 8hrs or so, no errors were found. At this point I am sure its not a software issue since I did a clean install of everything making sure everything was up to date before and afterwards. Now that it seems like its not the RAM, I don't know what to really do next to test the other components (ex. GPU, CPU, PSU, etc.). Any feedback/help will be greatly appreciated, thanks all!
