Hey guys, I just wanted some suggestions on what I should change with my build, and if it can run games like BF3 and Guild Wars 2 with high or ultra graphics. Also, I want to spend around $800-$900.
Computer Build-
Case- COOLER MASTER HAF 922 RC-922M-KKN1-GP http://www.frys.com/search?search_type=regular&sqxts=1&query_string=HAF+922+&submit.x=20&submit.y=10&cat=0
Mother Board- ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
Processor- AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
Graphics Card- PowerColor AX6850 1GBD5-DH Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity http://www.newegg.com/Product/Product.aspx?Item=N82E16814131374
Hard Drive- Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
SSD- OCZ Solid 3 SLD3-25SAT3-60G 2.5" 60GB SATA III MLC http://www.newegg.com/Product/Product.aspx?Item=N82E16820227728 (for boot-up)
RAM- Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PGD38G1600ELK http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558
Power Supply- RAIDMAX Blackstone series RX-700AC 700W Continuous Power ATX12V V2.3 / EPS12V V2.91 80 PLUS BRONZE Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817152042
Disc Drive- SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
Wireless adapter- Rosewill RNX-N180PCe Wireless Adapter IEEE 802.11b/g/n PCI Express Revision 1.1 Up to 300Mbps Wireless Data Rates 64/128-bit WEP (Hex & ASCII), WPA(TKIP with IEEE 802.1x), WPA2(AES with IEEE 802.1x) http://www.newegg.com/Product/Product.aspx?Item=N82E16833166063
Thanks![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Computer Build-
Thanks
