Question PC glitch with strange solution
Jack Ross
Commendable
Apr 19, 2022
15
I have been having an issue with my PC where it freezes on the tuf gaming logo when I first start it up. When it first happened I tried a number of different fixes including resetting cmos battery and basically everything you can think of. I then took the back panel of my PC off, had a look, put it back on, and all of a sudden it worked. At the time I thought it was a coincidence or just blind luck but now I think otherwise. This issue would’ve occurred over 10 times since then and every time it is fixed by simply removing the back panel and then putting it back on. I’m glad that it works but it is a bit annoying to do every time. Can anyone think of any possible reason that this would fix my issue? I can’t make sense of it in my head
Cheers
