I have purchased a new laptop, but when I started to use my old PC, RAM died on me.
OLD PC SPECS - Processor - Dual-core E2180, Motherboard Intel 945G, Seagate 80GB HDD, and 1GB Samsung RAM and 1GB Hynix DDR2 RAM.
I did not buy a new RAM and continue.
After, six months, I purchased two 1GB+1GB (Two separate orders) DDR2 RAM from eBay.
Installed fresh Windows 10 32bit & started to use it, But, it did not perform well.
Problems - It works for three to four hours after installation, but it gets slower after 6 hours of installation.
When you RESTART it using the button, it will have startup issues, then it never starts.
I have installed Windows 7, it works slowly and freezes for 10 seconds or 30 seconds.
I have installed Windows 10 Home (64bit) on another Harddisk, performance is still the same.
I have installed Windows 7 Ultimate (32bit) on a different hard disk and it freezes and works slowly.
NOTE: It uses to work smoothly on Windows 7 when I did not have a laptop.
UPDATE - Jan 18th 2018
After PaperDoc has suggested me to check the PC using third hard drive, I have installed Windows 10 32bit on Western Digital 80GB HDD (3rd HDD.)
I have read the suggestion on the same day he posted, in the mean time i was testing the HDD. I will test it for next four days, then i will update it.
