I don't know where else to ask, I've had issues for months now and I'm going absolutely crazy without my PC..
It first started when I opened up my PC and put in another graphics card, but I made the mistake of wearing wool fingerless gloves as I did this, and I'm afraid I might have given off a static shock to the motherboard.
My PC would either seemingly shut down due to a HDD error, or bluescreen whenever it got too 'excited'.
I swapped the graphics cards again, still same issue.. Reformatted, same issue.. I swapped motherboards, it worked for a few days (I used an old motherboard I had laying around, same one as I had put in currently) and then it broke again.
I took it to a store to fix it, they said they had no idea what it was.
Now, I have a few possiblities, but I need to be sure which one it is, as I don't have the funds to replace everything..
Etiher my motherboard is broken, one of my harddrives is broken, I may need to put new cooling gel on the CPU (as I did have to take it off to swap motherboard) or I don't know what.. I really hope you can help.
Edit: Specs'n stuff.
Cooler Master Elite 431 - Midi Tower - ( ATX / PS/2 ) - Black - USB/Audio
MB ASRock 970 Extreme4 AM3+ ATX
AMD FX-8120 8-Core 3.1 GHz AM3+ 16MB Cache 125W retail
ASUS EAH6750 FML_DI/1GD5 1024MB, PCI-
E, 2xDVI, HDMI
Seagate 8.9cm (3.5") 2 x 1.5TB SATA3
ST1500DM003 7200 64mb
DDR3 16GB PC 1333 CL9 Geil
2 x DVDRW 22x Samsung
Windows 7 HP NL 64 Bits
If you need a Dxdiag, I can get one too, but I have to hook up my PC first. I didn't see any attachment area.
Dxdiag:
Edit, Date: 15-2-2016
So what I did was apply cooling paste, check if it was the CMOS battery which it wasn't, took out my faulty HDD and my PC ran smooth, even better than before for two weeks.. Now today I've had two random crashes.
https://gyazo.com/be23bdf770f406c1f3b01623653204a6
I really hope it's a Software thing so I did in fact fix it.. I disabled updates due to updates constantly failing to install on my PC and it undoing them (that was two weeks ago, when I just reformatted it and it did that three days in a row)
Edit: (One day later)
I managed to finally get past the undoing updates for /now/ .. And now my PC is running incredibly hot again after the Windows updates, and my games are laggier. It feels like it's in the state it was in when my problem originally started. can Windows Updates really do this?
E, 2xDVI, HDMI
Dxdiag:
