bugcheck was an access violation in netio.sys
basically, the razer synapse made a call to nsiproxy.sys which made a call to netio.sys which ended up causing an access violation that caused the bugcheck.
(heap corruption)
first fix attempt would be to uninstall all of the razer software and services then reinstall the current version. Then run the intel driver update and pick up the installs and reboot. (see below for link)
notes:
looks like you have a old bios version. you might want to update.
looks like hp is not updating the drivers for this machine but you might want to check:
OMEN by HP Desktop PC - 870-244 Software and Driver Downloads | HP® Customer Support
ScpVBus.sys Sun May 5 14:31:26 2013 this version corrupts system memory, you need a version compiled in 2016 if you can find it. (fix was made in 2016)
you should use microsoft autoruns64.exe to delete this driver:
Autoruns for Windows - Windows Sysinternals | Microsoft Docs
note: running overclock drivers:
iocbios2.sys Tue Jul 20 11:42:28 2021 (cpu overclock)
(does not look like you have a cpu overclock. I would remove the driver with autoruns)
RTCore64.sys (gpu overclock driver)
might want to remove this driver:
IntelReadyModeDriver.sys Mon Mar 14 09:10:50 2016
(old intel update driver)
and go here to get intel updates:
Intel® Driver & Support Assistant
(it should pick up a update for your intel wireless network card, which would be the second fix attempt to prevent this bugcheck)
it should also update your intel storage driver.
would be nice to update the motherboard sound driver but the motherboard vendor does not have a proper update. (old version had issues with crashing GPU sound drivers and crash the GPU driver)
7: kd> !sysinfo machineid
Machine ID Information [From Smbios 3.0, DMIVersion 0, Size=3029]
BiosMajorRelease = 5
BiosMinorRelease = 12
BiosVendor = AMI
BiosVersion = F.10
BiosReleaseDate = 03/31/2017
SystemManufacturer = HP
SystemProductName = 870-244
SystemFamily = 103C_53311M HP Omen
SystemVersion = 1.04
SystemSKU = Z5M59AA#ABA
BaseBoardManufacturer = HP
BaseBoardProduct = 830C
BaseBoardVersion = 1.04
7: kd> !sysinfo cpuinfo
[CPU Information]
~MHz = REG_DWORD 3600
Component Information = REG_BINARY 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Configuration Data = REG_FULL_RESOURCE_DESCRIPTOR ff,ff,ff,ff,ff,ff,ff,ff,0,0,0,0,0,0,0,0
Identifier = REG_SZ Intel64 Family 6 Model 158 Stepping 9
ProcessorNameString = REG_SZ Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
Update Status = REG_DWORD 0
VendorIdentifier = REG_SZ GenuineIntel
MSR8B = REG_QWORD de00000000
