PC is not posting, I have literally tried everthing can anyone help me?
Jul 17, 2018
I had this problem previously when the pc did not have any power for about half a day or something like that. The fix that always worked then was reinserting ram a few times. It's doesn't seem to do the magic n I have been trying for about 2 days now.
All the fans and lights are working. I'm not hearing the single beep in startup which I used to previously.
Can anyone help me solve this issue? Thank you.
What I tried.
  • Switching Ram slots
    Trying a different Ram
    Reinserting GPU
    Changing SATA slots
    Removing CMOS battery for a few mins
    Removed dual monitors
    Tried with VGA and HDMI
Anomalies observed.
  • My mobo doesn't seem to have the CMOS jumper cap. And also my pc has a 2 pin CMOS jumper
My specs.
  • MSI 970-g43
    GTX 960 gaming edition
    8 gigs Corsair 1600MHz
    AMD FX 8350
    Dual monitors
What I can't do for the next few days.
  • Try my current components in other PC's.
I'm assuming you are unplugging the pc when you remove the battery. I don't know if it really helps but I always hold the power button a few seconds after I unplug it and pull the battery. Then wait 4-5 minutes to be sure.
Is there a chance wheather my motherboard or graphics card is dead? because some poeple i know think so. And is it normal for my motherboard to have no jumper with only 2 pins and not 3. If so can i put my friends jumper on my pc? .Thank you i will try what you mentioned at my friend's place.
Yes i did that twice still no post. Thank you for replying.
