Question PC Issues after Power Surge
Sep 11, 2024
Hello, so I recently built a pc about a week ago and all has been well until today a circuit tripped in my house and the power went out briefly. My PC did shut off while I was gaming, and it was plugged into a surge protector. Since then, when I shut down the PC either situation 1) the PC shuts down, the motherboard lights stay on, and the PC can power up later no problem with the fans spinning and the RGB on the fans turning on, or situation 2) the PC shuts down, the motherboard light goes off, and the PC does not power up normally and the motherboard has a light on indicating CPU and dram issues while the fans spin (without RGB). When situation 2 happens, I have to do some combination of unplugging the PC, turning off the psu and holding the power button and turning it all back on to get the PC working again.
It is worth noting that I had this issue (situation 2) happen a few times even before the power outage, but the power outage seems to have exacerbated the issue. Also, this may be a complete coincidence but I think my psu has more coil whine after the power outage than before (really unsure about this, it was never exactly silent beforehand). I was wondering if this is a psu issue, motherboard issue, windows shut down issue, power strip issue, or something else entirely. I would appreciate any tips. It may not be important, but when the power first came back on I had to clear the CMOS to get the PC to turn on and display again for the first time. I'm really at a loss for what to do and I just want to enjoy my PC without this problem.
Edit: full PC specs
CPU: AMD Ryzen 7 7700X
CPU cooler: Thermalright Phantom Spirit
Motherboard: Asrock B650M PG Riptide
Ram: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30
SSD/HDD: Samsung 980 pro 1tb
GPU: Zotac RTX 4070 TI Super
PSU: Corsair RM850e
Chassis: Asus Prime AP201
OS: Windows 11
Monitor: MSI G274QPX
Bios version: 3.06 (newest)
PSU used for less than 20 hours
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
You might want to see if reflashing the BIOS to the latest helps your predicament. After you've verified that your BIOS is flashed to the latest version, clear the CMOS. In order to do so, disconnect from the wall and display, remove the CMOS battery and press and hold the power button for 30secs. Replace the battery after 30mins.
You might want to also see if you're having a grounding issue in your abode. Things like this can happen after a power surge and if the power lines are...compromised.
Motherboard: asrock b650m pg riptide
PSU: Corsair RM850e
Take the surge unit out of the mix....test.
