PC Issues / Problems
Brodie
37
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
This is going to be long winded, so sorry for the lengthy read. I am having
some issues with my PC, first off I changed my drive from FAT32 to NTSF.
After the change, which I hadn't noticed for a while, my system restore
would not work. In My Computer > Properties, there is no check in the "turn
off system restore". Under the Services tab in the Administrative Tools it
says that it is stopped, when I hit start it gives me an error stating
"Could not start System Restore Service service on local computer" "Error
1359: An internal error occurred" That is the first issue. The next issue is
that I downloaded some software that I probably shouldn't have, I ran into
some problems with it so I uninstalled it and ran all of my stuff ( Spybot,
AVG, Bazooka, AdAware) to see if it left some stuff behind (Bazooka detected
B3D Projector and Winpup) which I tried to get rid of by using the procedure
they suggested but what I was supposed to delete was not in the registry.
When I try to run Nero, the PC reboots. I have absolutely no clue. I
uninstalled and reinstalled Nero but to no avail. There is another program I
have called TuneUp Utilities. I can run all of the options, but when I try
and use the "TuneUp System Optimizer" option the system also reboots. I'm
not sure what the connection is, but it is odd. I either don't have or can't
find my XP disc, the computer came preloaded so I'm not sure if I even got
one, so I can't backup everything and start form scratch. Does anybody have
any suggestions? Thanks for your time.
> having some issues with my PC, first off I changed my drive from
> FAT32 to NTSF. After the change, which I hadn't noticed for a while,
> my system restore would not work. In My Computer > Properties, there
> is no check in the "turn off system restore". Under the Services tab
> in the Administrative Tools it says that it is stopped, when I hit
> start it gives me an error stating "Could not start System Restore
> Service service on local computer" "Error 1359: An internal error
> occurred" That is the first issue. The next issue is that I
> Spybot, AVG, Bazooka, AdAware) to see if it left some stuff behind
> (Bazooka detected B3D Projector and Winpup) which I tried to get rid
> of by using the procedure they suggested but what I was supposed to
> delete was not in the registry. When I try to run Nero, the PC
> reboots. I have absolutely no clue. I uninstalled and reinstalled
> Nero but to no avail. There is another program I have called TuneUp
> Utilities. I can run all of the options, but when I try and use the
> "TuneUp System Optimizer" option the system also reboots. I'm not
> can't find my XP disc, the computer came preloaded so I'm not sure if
> I even got one, so I can't backup everything and start form scratch.
> Does anybody have any suggestions? Thanks for your time.
Would you care to repost, this time using *PARAGRAPHS*?! They make long
blocks of text so much easier to digest.
Thanks so much.
My great-grandfather was born and raised in Elgin - did he eventually
lose his marbles?
Hi,
What version of XP are you using and how did u upgrade to NTFS from FAT.
Regards
M. Rajesh
..Net and Windows Shell MVP
www.winxpsolution.com.
