[SOLVED] PC keeps losing connection to to the internet, using ethernet.
Kvahuest01
Commendable
Aug 20, 2020
73
Router - BT Smart Hub 2
Motherboard - ASrock Extreame4 z370
The internet will only drop on my PC, google etc will still load on my phone, it usually disconnects for like a minute or so then reconnects but sometimes i have to pull the ethernet cord out and plug it back in. The problem only just started to show up, been using the same ethernet cable for about a year now, anyone know of any issues that may be causing this?
The ethernet cable does not require specific drivers or drivers at all.
You can try any other available, known working, Ethernet cable(s). Cat5e or Cat6.
What Ethernet connection are you using on your PC: Built in LAN port, Ethernet PCIe card, or perhaps a USB to Ethernet Adapter?
Check the applicable LAN port for signs of damage or debris inside. Use a bright flashlight. Ethernet cable plug should fully and firmly clip into the LAN port.
Try another known working Ethernet cable.
Make and model information for the Ethernet adapter(s) being used? Ensure that only one Ethernet adapter is enabled.
Manually download the applicable Ethernet adapter drivers via the manufacturer's website. Reinstall and reconfigure.
the ethernet cable goes from my pc directly to the router, got no clue what the make of my ethernet cable is so i cant really download the drivers for it.
