Question PC making USB disconnect and connect sound every few minutes/seconds
Guitto
218
I am having an issue with my PC where it starts doing the USB disconnect and connect sound. It happens every few minutes, but then it sometimes happen like 5 times in the span of 2 minutes. I have downloaded USBLogView, and this is what came up, but i have no idea what any of this means:
https://gyazo.com/4311bce675b8f8c81f40eab4afcafeea
Can anyone help me out about this issue? PC specs down below: I also think this started happening after i installed my new Lian Li fans ( UNI Fan SL-INF Reverse Blade x6)
Specs:
CPU: Intel Quad Core i5-13600k
CPU Cooler: Lian Li Galahad II LCD SL-INF AIO
GPU: RTX 4070 SUPER
Motherboard: Asus Prime Z790-A
RAM: Corsair Dominator Titanium DDR5 2x16gb 6000mhz
SSD: Samsung 970 EVO 500GB + 1TB
Hard Drive: Stagate Barracuda 1TB 7200rpm
PSU: Asus ROG Strix 850w
EDIT: I have also ordered a new USB splitter for the motheboard, as maybe the current one is broken or not working properly ? Perhaps it doesnt have enough power for the fans to work properly?
What BIOS version are you on for your motherboard?
If you suspect the fans to be the root of the issue, remove(disconnect) them from the system and see if the issue is remedied.
Mind sharing the USB splitter you're working with now? As for your splitter, why do you need one?
08/08/2024 version for BIOS
I could do that, yes, remove them and see if it still happens.
Im also using this right now:https://www.amazon.co.uk/Rocketek-M...523499&sprefix=usb+splitter+mob,aps,83&sr=8-3
I need it because the mobo does not have enough USB ports as im also using the Lian Li RGB cable for the mobo and GPU
