This started happening yesterday, PC wouldn't turn on right away, took like 3 minutes after the first attempt, I re plugged the PSU, turned it off, clicked on the power button, re plugged everything until it finally powered on.
At night it took 10 minutes, I ended up also removing the ram sticks and cleaning them, I placed 1 correctly and the other not, it POSTed with the beep, I put back the ram correctly again and it booted normally.
Today it happened the same thing, it took like 2 minutes of attempts, re plugged the PSU from the wall in my attempts and it finally powered on.
To be clear, no fans would run or leds would power on.
This also only happens if the PC has been shut for like 1-2 hours, if I restart it while I'm using it, it will power on right away as it is already "warmed up".
Everything is running smoothly while it is powered on, no ram issues afaik.
Before this, the PC would fail to power off completely sometimes (I think my z370 is at fault because it didn't happen with the z390) and would even power on again by itself, I had to hold the power button or turn off the PSU because it would never power off, restarting would sometimes leave it hanging in the limbo state.
I have the following components (everything is compatible):
i7 9700k (not OCed)
z370-a pro (only taken out of the box 6 months ago)
2x16gb (XMP settings but in manual, same voltage, clock and timings)
rtx 2080 (not OCed)
2x hdd 7200
m2 sata ssd
pcie ssd
pcie wifi card
seasonic focus+ gold fx 750w
i7 9700k (not OCed)
rtx 2080 (not OCed)
2x hdd 7200
m2 sata ssd
pcie ssd
pcie wifi card
