Hi guys,
I have finally decided to build my own PC, as I would need it for Audio production I wanted to have my own setting. Unfortnately i encountered some problem and I dont know what to do anymore.
The specs are:
When i try to boot, all fans and cooler running, Motherboard lights on - but I have a red CPU light and I get various error codes from the motherboard each time I start to boot, e.g. like 52, 31, df, A1 - which seems to be all Memory related.
I have tried various RAM settings, taken them out one by one in different sockets and combinations, checked if they sit properly until they click but nothing woked. I have reseated my CPU twice carefully and checked for bent pins, but couldnt find anything suspicious. I have also tried to update the BIOS from flashdisk, but the BIOS LED blinks 5 times and then stays illuminated for hours until i shut down the system.
I think it could be the update of BIOS which causes problems but i dont know how to make the update happen correctly...I downloaded the CAP data with the rename.exe and copied the new file on a fresh USB stick, but doesnt seem to work.
Does anyone have help for me? Dont know what to do anymore, I also dont know if what i have done is correctly or if maybe the Motherboard or CPU couldve been damaged. But how do i find out?
Thank you very much in advance.
M.
The specs are:
- ASUS Strix x299 e-Gaming
- Intel i9 10900x 10 Core
- be quiet dark rock pro 4
- be quiet pure power 11 700 watt
- Samsung ssd 970 Evo 1 TB
- Samsung ssd 860 QVO 2 TB
- HyperX Predator DDR4 4x16gb RAM 3000 mhz
- ASUS amd Radeon arez rx 550 graphics Card
M.
