Question PC NOT running properly
Mar 27, 2020
14
My pc is running worse than any other video ive seen of it on yt. Like they get 80 percent gpu usage and i get 50-60
MadsModsat
828
154
640
45
So what kind of system do you actually have?
Was this just a statement, or are you asking for assistance?
Full system specs, including make and model of the PSU and all other components.
Barty1884
What are your specs, and what are you doing with it?
How old are YT videos you're comparing? and are you matching settings etc 100%?
Remember, updates, patches etc can change things. Even with that, you have to take (certain) YT videos with a pinch of salt.
Mar 27, 2020
14
Hi there. Since the past couple of patches my gpu usage has really decreased in fortnite. Went from around 150 fps with barely any stutter to 100 fps with a fair bit of stutter. GPU usage used to be around 75 percent with cpu at 50 but now its like the opposite way round. 40-55 percent gpu usage with 100 fps and 70-90 percent cpu usage. Any help appreciated. Thanks
Mar 25, 2020
5
I got similar problem, i got almost same specs except processor i got i5 3570 and also i got stutter in fortnite, and same gpu usage, and frame drops like from 100 to 5fps... and if you find a fix please let me know :)
Mar 27, 2020
14
At first i thought it was optimisation, but yt videos say otherwise, with them at 70-90 percent gpu usage and over 130fps at most times
