My PC is not starting up/turning over. Currently with my PC when I turn on the power button. My External fan + LEDs & GPU fan all start apinning as expected as normal. But with my CPU fan it does not spin. The PC/Motherboard when turned on also does not make ANY beep/beep codes. Not one pepe. When trying to turn the pc. My power button is unresponsove even after holding it for 5 seconds to do a forced shutdown. The only way to turn it off is via my pcs powerbox awitch or via the wall socket. But when turning it off my CPU fan respons by giving a single jitter. Not enoough to move even 1 blade width. But noticable when stopping it. Ive already changed out my powerbox with an identical one to rule it out. Same problems
