PC not working after Motherboard, CPU and RAM replacement.
thatskillz
23
So when I press the power button, everything inside of the computer seems to be working, fans is spinning, front LED is working etc. However, screen is black, keyboard and mouse LED is not working, as well as computer is rebooting again and again within a proximity of about 15 seconds. The components I swapped:
asus m5a97 r2.0 -> ms 7826 ver 2.0 from HP
fx-6300 -> i7-4790
hyperx 2x4gb 1600mhz -> samsung 4gb+8gb 1600mhz
The thing is that the ''new'' components that I installed was from a second desktop that i've had for a while and theres been no problem before. Any help is appreciated.
Thanks for the reply, after a bit of troubleshooting, everything seemed to be working fine when I took out the GPU and used the integrated graphics. How can I install the GPU without it causing the same things to happen again?
Sorry for late reply,
Updated the bios, still no signal when GPU is installed.
