Title mostly says it all but when i do not have the 4 pin cpu power connector plugged into the motherboard the pc starts up and everything comes on. Once i connect the CPU power connector to the motherboard, the pc will start up and run for about 5-10 seconds and then shuts off again and will keep restarting until i turn off the PSU. Note this is a newly built pc. Thanks in advance for any help/suggestions.
Build:
INTEL® CORE™ I5-6500 Processor 6M Cache 3.2GHZ Up to 3.60 GHz FC-LGA14C LGA1151
Kingston HyperX Fury Black 8GB 2X4GB 2133MHZ DDR4 Non-ECC CL14 DIMM Dual Channel
GIGABYTE GA-H110M-A Core H110 LGA1151 DDR4 SATA PCIe mATX Motherboard
Seagate Barracuda ST1000DM010 1TB SATA 6GB/S 7200RPM 64MB Cache 3.5in Internal H
EVGA GeForce GTX 1050TI SC Gaming 4GB GDDR5 DX12 OSD Support Video Card
NZXT Phantom 410 ATX Steel Computer Case 3X5.25 6X3.5 3XUSB3.0 Audio and Mic Inp
EVGA 500W 80 Plus White Active PFC 12V 34A Power Supply 120mm Fan 3 Year Warranty
Build:
