Last night unfortunately my pc randomly cut out, i turned it off at the outlet and turned it back on again. The lights turn on for a split second and then all turn off, the only thing that is left on is the front io power led.
My suspicions was that it was the psu so i switched it out for a new on and nothing. so i tested the cpu 8 pin power cable by unplugging it and it powers on without any problem. But obviously i cant boot into windows or bios without a cpu. i plug the cable back in and the problem persists.
i believe that the cpu is cutting the power of the whole pc as soon as i press power on because its fried or something, am i correct?
is the issue with the motherboard or the cpu and is it fixable?
If you need any more information please just ask.
