Hi everyone, I live in India and here in Summer's we get baked by Room Temp of 42° - 45° Celsius and my Core 2 Duo E7500 has an Idle Temp of 48°c - 52°c with stock Cooler and without Overclocking .
Now when I play Heavy Game likes Battlefield 3 then Processor gets under 100 percent load and temps go over 80°c and my MotherBoard gives me a Buzzer Sound due to overheat and sometimes It also causes Blue Screen error .
Now I don't have much Budget, The Cabinet I have supports 2 80mm Fans from Side Panel and 1 80 or 90mm Fan from Back Side . I want to Know If I can keep my Cabinet Cool with those 3 Fans ( I Don't have Any Fan in my Cabinet except Processor, GPU and PSU Fan )
Or I should get a CPU Cooler ? As I said I don't have much Options so I've selected a CPU Cooler and Its Name is - Deepcool Gammxx 300 Tower Cooler .
This Cooler is LGA775 Supported but I always feared Tower Cooler Due to the Massive Weight Attached to the MoBo . Now I have Gigabyte G41M-Combo MoBo . Will My MoBo be able to support the Weight of this Tower Cooler ?
P.S - While Monitoring with RealTemp, While I was Scrolling in Facebook the Temp went to 60°c to 64°c :/
