PC Overheating Issues, need help.
Zobbar
54
Hello,
I recently upgraded to Crossfire and its been great ( I can now do 4k). There is one major problem... My 2nd (Bottom one) is a 7870tahit and it gets real hot, it runs at ~90C and once it reaches around 92C it makes my PC crash and the screen gets black with random dirty white lines near the top and then shuts off, during this process the headphones make a terrible noise sounding like baaaaaa electronically. The 1st gpu 7950, is at a good temp. (77-85c) and does not make issues. Note all fans are on max rpm. What can I do to fix it?
That will cost me $40 for both of them because of XFX shipping D:.
Can it just be the software's fault... just 3 days ago the temps were 77c for the 7950 and ~83c for the 7870 tahiti.
How does it jump so high. There was a difference in temp for the room but not that high!
Only 1 card was in there and as far as I remember temp was a bit (2-3c) better... 5c at most, let me check.
Yes little bit less than 5C difference outside, in home it should be less. It's just wired that the temps. for both gpus spiked up so much... Just earlier today the 7870xt was at 92 and the 7950 was at 83.
This one looks like its better, so I deceided to switch! Should I get the bit fenix one back?
Just something to add... 3 days ago, weather outside was 5c less, so less in the room, and the cards were 7870xt 83c and 7950 77c. 6 hours ago temps were 7870xt 92c and 7950 84c.
This is a dramatic change that I cannot explain! Any help?
That's not a very viable option and it's a last resort...
I just can't understand why this is:
This is a dramatic change that I cannot explain! Can you answer it?
Thank you for being so helpful you are so kind 😀
