Question Pc power button flashing when turning on
Mar 4, 2024
Hello to everyone,
I just build my first pc the other day. Everything seems to work just fine, except for the turning on of the PC. When I press the button to turn on the PC, everything turns on(Fans, rgbs...) except for the display for a good 10sec. In that 10sec the power button blinks white and than it just starts normaly. If you need any kind of info I'll be glad to tell you. Thanks for anyone taking their time to answer my question.
Vid of the problem: https://www.reddit.com/r/PcBuild/comments/1b4kwqw/comment/kszpx24/
Config:
CPU: AMD Ryzen 5 7600X
GPU: RX 7800XT
RAM: 32GB DDR5 5600Mhz
Mobo: ASUS Prime A620M-K
PSU: Cooler master 700W 80+ bronze
OS: Win 11 Pro 64-bit
Coolermaster is the brand of the unit, while 700W is the advertised wattage of the unit. Likewise the 80+ bronze is the advertised 80+ efficiency rating.
Did you wire the front panel connectors the right way? People have made that mistake even long time builders, not just newcomers tot he industry/hobby.
Reactions: fiKo
Thanks for taking the time to reply.
View: https://youtu.be/dZlX1Tmkggk?si=beRF5YcSueWEkczA
This is the vid I watched on how to connect almost everything. I have the
Power led + and -, power sw and hdd led cables connect like in the vid, but the reset cable I have connected to the pwm hub from the case so I can change the fans color. But, just for information I don't think that actually works as when I press it it doesn't do anything. I can only change the colors for the fans from the mobo software.
Latest posts
