G geoffrey_8 Commendable Jul 16, 2016 11 0 1,510 Dec 24, 2016 #1 When i try to boot up my pc it displays "The boot config data file doesnt contain valid info for an os" + "File:\Boot\BCD"+"Error code: 0x0000098". Eventhough im booting it from my installation media tool (usb drive). help!?
Colif Win 11 Master Jun 12, 2015 67,209 7,041 168,140 Dec 24, 2016 #2 So USB is first in boot order? as that sounds like the hdd instead. What motherboard do you have? what you probably need to do is this: https://www.lifewire.com/how-to-rebuild-the-bcd-in-windows-2624508 Upvote 0 Downvote
G geoffrey_8 Commendable Jul 16, 2016 11 0 1,510 Dec 24, 2016 #3 Colif : So USB is first in boot order? as that sounds like the hdd instead. What motherboard do you have? what you probably need to do is this: https://www.lifewire.com/how-to-rebuild-the-bcd-in-windows-2624508 my removable device (usb drive) is set to first priority and ive set the usbdrive as priority in hard disk drives. i have a M5A 78L-M LX3 Upvote 0 Downvote
Colif Win 11 Master Jun 12, 2015 67,209 7,041 168,140 Dec 24, 2016 #4 a few suggestions: https://www.reddit.com/r/buildapc/comments/427aov/troubleshooting_asus_m5a78lm_wont_boot_from_usb/ Upvote 0 Downvote
G geoffrey_8 Commendable Jul 16, 2016 11 0 1,510 Dec 24, 2016 #5 Colif : a few suggestions: https://www.reddit.com/r/buildapc/comments/427aov/troubleshooting_asus_m5a78lm_wont_boot_from_usb/ did the steps and ended up with the same outcome Upvote 0 Downvote
Colif Win 11 Master Jun 12, 2015 67,209 7,041 168,140 Dec 24, 2016 #6 is it the USB you installed win 10 with? In other words, do you know if it works? i can't find a lot on this so it can't be a hard problem to solve, you might be best asking on Asus forums. Upvote 0 Downvote
