Hi, i recently bought a 780ti ro replace my broken r9 280x and a noctua NH-L9x65 cpu cooler. However when installing the cooler the cpu came off with the hold heat sink and bent one of the cpu pins slightly. I managed to bend the cpu pin back into shape and the pc still boots with everything working for standard use with nothing overheating.
However, recently when playing games such as PUBG and BF1 and even csgo etc my screen goes black and my mouse and keyboard turn off into about 5 minutes of gameplay which forces me to reboot my computer to get a display. Bare in mind this is only for games and normal desktop use is fine.
At first I thought it was the psu which was causing the issue but I recently bought a 2nd one (corsair vs 650) to see if my corsair cx 750 was the problem. However the same problem occurred. Ive also tried using a different plug, wall socket and room in my house and I still get the same problem.
Next I tried taking the 780ti back to the store which I bought it from which they tested in games and they did not get the same result. So the gpu is not the issue.
I have also done game re-installs, windows reinstall, driver re-installs, under clocking the gpu, stress testing the gpu, monitored gpu temps in game and it never went above 75 degrees and disk fragmenting etc and which I get the same result.
Has anyone got any more ideas on what the problem could be or suggest a fix? I'm running out of ideas and quite personally don't want to be spending more money on a new motherboard, cpu and ram as im trying the save for university.
Thank you
pc spec below if it helps ![Smile :) :)](/data/assets/smilies/smile.gif)
Pc specs
Amd fx-8350
Asus M5A-78lm/usb3 am3+ motherboard
evga 780ti superclocked edition
8gb corsair vengence ram @ 1600mhz
corsair cx 750 (no modular)
1tb seagte barcudda 7200rpm
1tb WD caviar blue 7200rpm
120gb crucial m500 ssd
corsair air 240 case
4X corsair af 120mm fans white
corsair raptor k50 keyboard
logitech g502 spectrum mouse
steel series arctics 5 headset
Thank you
Pc specs
Amd fx-8350
