My PC restarts while playing some games (e.g. CS:GO, Assassin's Creed Odyssey) so I installed different utilities such as Prime95 (v30.3) and OCCT to run some tests.
With Prime95 Small and Smallest FFTs, the PC restarts instantly.
With Prime95 Large FFTs, the PC didn't restart after running the test for 10 minutes.
The PC also restarts instantly with OCCT CPU Small Data Set AVX2 and OCCT Power Test AVX2.
HWiNFO logs are available here: https://gofile.io/d/GhCjEQ
Some screenshots from OCCT: https://ibb.co/album/bgTjyt
I have the following configuration:
Motherboard: MSI Z370 GAMING PRO CARBON AC
CPU: Intel Core i7-9700K
CPU Cooler: Alphacool Eisbaer LT120
GPU: MSI GeForce RTX 2080 Ti DUKE
PSU: Cougar Power 700W (CGR B2-700) 80 Bronze Plus
Memory: Patriot Viper 32 GB (4 x 8 GB) DDR4-3200 CL16
The estimated wattage on PCPartPicker is 484W.
The components are not overclocked AFAIK (BIOS screenshot) and I don't have any experience with overclocking.
I set the RAM frequency to 3000 MHz and toggled XMP on/off but the problem persists.
What could be the issue? Could it be the PSU?
I don't care about passing the tests but I don't want the PC to restart while gaming.
My thermals are not that great (~35°C idle but ~80-85°C while gaming) and I'm considering moving everything to a new case with 240/360mm coolers.
Thank you in advance!
