Question PC restarts randomly and won't always turn on ?
Sep 4, 2023
Hi,
Issue:
For a while my PC has occasionally restarted on its own - seems to be fairly random. The restarts don't seem to be related to heavy load - at least during gaming it has only happened once or twice, whereas just being on Discord or using chrome for normal browsing has caused a lot more restarts.
There's no BSOD or anything - just a reboot.
Recently, I sometimes cannot even turn on my PC - even if I drain all static residual power etc. etc.
What I tried:
  • Removing the MB battery and BIOS reset
  • removing all dust from all components
  • swapping RAM slots, trying only 1 stick in different slots
  • swapping power cables
Question:
My guess is that my PSU is faulty, but before I run out and buy a new one I'd like to know if any of you suspect something else to the culprit?
Specs:
PSU: Corsair RM850x
CPU: 10700k
MB: Asus z370
16gb DDR4 G.Skill 3000mhz..
Thanks in advance!
